Silver 2000 167,000 miles (named Ravi) Timing belt/water pump/alternator replaced at 92,000, OEM battery replaced in last 10,000 miles. Oil Changed Regularly, Coolant changed and levels are proper.
I have an intermittent problem.
CEL Came on, then starteding flashing and Ravi threw codes P0171/P0300/P0301/P0304-I parked it and I did the following
New NGK OEM Spark Plugs (4)
New OEM Plug Wires
New OEM Ignition Coils (2)
Fuel Injector Cleaner
Checked all hoses for vacuum leaks- found none
Fuel Cap checked- no leak
Codes were cleared and she drove perfectly (better than before-better acceleration/mpg/smoother/quieter) for 2 weeks. Then flashing CEL and she threw codes P0300/P0301/P0304. Parked it, bought an OBDII reader and started it up, all codes were gone. Drove it for 1 week and today, flashing CEL and codes P0300/P0301/P0304 again. After checking codes, turned it off, restarted and it ran fine again and CEL went out. Not sure what direction to go.
Help, I can't trust Ravi right now!
Code Legend:
P0171 System too lean bank 1
P0300 Random Misfire detected
P0301 Cylinder 1 Misfire detected
P0304 Cylinder 4 Misfire detected
New OEM Plug Wires
Code Legend:
