Sun Shade for Navigation Screen
17K views 24 replies 12 participants last post by  M2R
Has anyone found a Sun Cover for the Navigation Screen?. At certain angles the Sun fades the screen out almost completely.
#3 ·
I plan to make my own and here is a suggestion that I will try:
At the craft stores and on the net they sell thin colored foam sheets. I would use black). I was going to buy a black one and cut a strip about 1 or 2" wide. Then I would use thin velcro strips, I'd cut the 1" wide strip in half length wise, to make something about 1/2 or even narrower strips about 1" long. then bond the strips to the edge of the foam pad and the other part of the velcro to the edge of the display. I think with a little experimentation as to the width of the foam that works best for you might be necessary.
#5 ·
On my Rav it doesn't have nav and I am glad because I can't see the screen if the sun is out. I seem to get a reflection off my clothes in the screen from sun shining on my clothes. Not sure if a sun screen will provide relief from that. I tried to block sun from the screen but it didn't work. I use a 7 inch Garmin in the center storage area, fits perfect and no issues seeing the screen. Also you can change information even when car is moving.
#10 ·
#15 ·
its a sticker base, mine hasn't fallen off (yet). just practice clean surface before adding the sun shade.
mine hasn't warped from the heat, i live in cali ... and it hasn't been that hot yet.
I cleaned the area very well before putting it on. Applied plenty of force and kept it in the shade [garaged] for a few days to go hard. So far so good. It provides plenty of shade for the screen and looks a lot better than the screen jutting up out of the dash.
#24 ·
Aliexpress Visor - Too Large
Aliexpress Visor Top - Amazon Visor Bottom
The anxiously awaited sun visor from Aliexpress came in today and was a big disappointment. It is easily 2" too long for my standard head unit (I don't have navigation or the larger screen). Maybe this fits on some RAV4's with a different size head unit, but not on mine with the standard one. It is too bad because I prefer this design and the visor part extended more than the one I had purchased on Amazon.
I have contacted the seller to return the item and get a refund. Maybe they sent the wrong one, I don't know. We'll see what they have to say. For now I will reinstall the smaller Amazon one until a better option comes along.
#25 ·
I sent a message to the seller of this product advertised on AliExpress to fit the RAV4. Do not buy this visor. I have sent the one received back and am awaiting to see if I will get a refund.
I asked the seller if they had possibly sent the wrong product. The seller sent back two responses that I have included below.
"Hi friend, this product is suitable for this version of navigation. if you do not mind. I suggest that you can cut off the excess cover. This will not affect its function."
"so sorry. we only this style for RAV4. If this product is too long, I suggest that you can cut off the excess. If you can modify it to make it function. We give you other compensation."
Never know what you will get when ordering on the web.
