Hi everyone. I’m a new customer to Toyota. I have a 2003 RAV4 4WD. I’ve always worked on my own 4WDs in the past, but I have a problem I’d like to ask help with. I cannot access the front differential filler plug! It’s in a very tight spot where the exhaust passes right in front of the filler plug, therefor blocking access to it. Is there a special tool I need to access the filler plug? It just seems a bit excessive to remove the front section of the exhaust to do a front differential fluid change. Any help or suggestions would be much appreciated.
Many thanks!
Many thanks!
