100,000 mile service recommendations- 2021 Rav4 Hybrid
4.4K views 17 replies 9 participants last post by  Mar Espejo
#1 · (Edited)
I purchased my '21 Hybrid XLE Premium new in January 2021. I drive ~30k/year and just hit 100,000 miles. All services have been done at Toyota so far, I purchased the ToyotaCare service plan from a dealership I trust and have never been scammed for add-ons before... I brought it into a different dealer at 90k and was recommended drain& fill cooling system, Brake system fluid exchange, hybrid inverter coolant change, and drain& fill Auto trans (world standard fluid). Totaling $800+ (before they had even worked on my car), I laughed and declined all extras and plan to bring it back to my trusted dealer for 100k service.
I see in the owners manual it recommends Replace engine/ inverter coolant, how much is appropriate to pay for this (in California)? And is it really needed at 100k or could I go longer?
Also is cleaning the HV Battery cooling intake filter an easy at home task? is it worth just replacing the filter, looks to be only $5 for a new one.
So far I've only done oil changes, tire rotations, new tires, and new engine air and cabin air filters for this car. Is there anything else really necessary at 100k or in the coming 25k after?
Replacing the coolants at 100K is recommended for severe service such as trailer towing, mountain driving, and cargo on the roof. Perhaps 30K miles a year would quality as severe service.
The HV battery filter is super easy to DIY. Go for it.
Shocks? Do a bounce test to see if they are bad.
Spark plugs, perhaps.
#9 ·
For a reference, I purchased a 1998 corvette that has ALOT of highway miles. I checked the spark plugs at the time of purchase with 229K miles on the car. The plugs were the original platinum plugs the car came with (I know this because the part numbers were superseded twice and these were the original part number). The platinum tips were intact, but the metal supporting the platinum had eroded under the platinum and the tiny piece of platinum had almost fallen off the plug. This car did not have any drivability issues and ran perfectly. That being said, the plugs can absolutely go for over 100k miles, probably 200k as long as the gap is good and there are no other engine issues or contaminants on the plugs. That being said, I would change them myself at 100k miles to keep the maximum efficiency of the engine. 4cyl spark plugs are typically very simple to change.
I agree with the ecvt transaxle fluid change at 100k. That's an appropriate mileage to be safe. We had a camry hybrid, same basic design Ecvt. I changed mine at 115k and it came out slightly darker than the new. However, the color is not the only indication of the fluid's capability to keep the MG's cool. I would change it to be safe. The good news is it is so simple you can do it yourself if you want to save money. There is a drain plug and a fill plug and it is simply filled to the top of the fill plug.
#8 ·
I will say one other thing. If you are restrained by your budget and cannot complete all the advised services, here is some more information you can consider to prioritize these services:
Coolants - This will degrade over time and become acidic which will eat through the aluminum of the cores used to radiate heat. Depending on the coolant used, that may happen in 2 or 10 yrs. The acidity could probably be tested with a PH test kit. The coolant should also be tested to verify it still has ability to not freeze. I would recommend thsi be done at the dealership as I believe to get it all, it must be flushed with a pump system.
Transaxle fluid - Based on my 115k mile 2018 camry hybrid with very similar design transaxle and my experience with the fluid looking very near to new and what I know: These transaxles do not have a torque converter or a clutch pack like a conventional automatic and do not have a chain like a typical CVT transaxle. Therefore, there are no sacrificial wearing parts and very little contaminates in the fluid. If it were my car, I would do this as one of the lower priorities, but probably complete this myself. For mine, I bought the fluid and purchased a very large fluid transfer syrenge to help transfer fluid.
Brake fluid - Brake fluid absorbs water THROUGH the rubber brake lines and eventually becomes as saturated as possible with water. This reduces the boiling point temperature. In the event of a hard/long braking situation like a long downhill or hitting the brakes hard, the brake fluid gets very hot since it is right next to rotor and pads. If the boiling point is never reached, the fluid will not boil. If it does reach the lower boiling point, the fluid boils, and gas is created in the brake lines. This creates a system with spongey feeling brakes. This would be my main concern with not performing this service. That being said, I have never had a car that I have driven that has ever reached this point. I did buy a 2500 Chevrolet avalanche that had spongey brakes and resolved this by bleeding. It was likely towing something heavy and overheated the brakes. In my opinion, if it were my car I would wait based on my brake usage if budget did not allow.
Battery filter - I would clean or replace myself and never skip this service as I want to prolong my battery life and this is cheap and simple.
I hope this helps!
- Mark
#11 ·
The warranty and maintenance manual is in the glove box or at Toyota.com.
As far as pushing intervals: It is your machine and you are taking the risks. Do want you want.
However the facts are plugs that misfire are far worse in a hybrid with no torque converter. It causes a severe engine to transaxle damper slippage that sounds like a thrown rod.
Transaxle fluid insulates the windings of the electric motors inside. It is special and important.
Brake fluid protects the highly expensive brake by wire master cylinder. Three or four thousand at a dealer to replace.
Coolant protects the Uber expensive aluminum engine. Eight to ten thousand to replace.
The hv battery filter protects the four thousand dollar battery and warranty you still have at 100k.
But it is your machine; do what you want.
