I am wanting to pull the rear wheel abs sensor to clean it. Can someone tell me how to extract the sensor from the hub assembly. Does the round piece just pry out ,as it would just be a press fit holding it in? The front was quick and easy. Thanks
Fred has the 4WD, which uses Rear Speed Sensor (for 4WD).I am looking at the right rear at this time and did not see a bolt other than what secures the wire to it . Am I missing something?
How did you actually remove the sensor? Were you able to get it without removing the hub assembly?Curious if the 2006 Rav4 has a different wheel sensor than the ones described in the various "wheel sensor cleaning" sites? I've been having the famous 4 light ABS/Brake/VSC issue lately and the codes returned the right rear wheel speed sensor. I took the wheel off and removed the sensor this weekend (what a pain.. it was rusted in the hole) but the sensor itself is an enclosed black piece of plastic and was clean as a whistle. There was no metallic strip covered in dirt as described on the various posts, but rather a nice clean black sensor. Am I missing something here? What is there to clean off?
Yes, you have to lube it real good and twist it side to side gently, but it cam be worked out. It does not screw in. What I found was the rust buildup had probably increased the gap to the starwheel. Cleaning it all up good kept the lights off for maybe six months. When they came back on I replaced the sensor.
