Hi,
Hard to describe this problem in technical terms, but here goes. My girlfriends 96 Rav4 ( 65,000 miles, serviced every year since new ) has started to 'play up'. I haven't driven it myself since before the winter when it was as good as always, nice smooth drive, easy throttle response, no problems.
At some point over the winter something has happened. Most of her driving is around town so with 'crawling' speeds of 15-25 mph on average it's hard to tell how long it's been going on, but now, either hot or cold, the throttle will respond intermittently. You can get in from cold, turn it on and take off no problem, other times it's a struggle to get it up to 30mph. It 'chugs' or jumps as if firing on only a few cylinders, but then you floor the pedal and it races off no problem. I haven't managed to get it over 60mph though it used to hit 70+ easily.
Fuel economy has dropped due to having to floor it to get any real throttle response rather than cruising it.
It really is a hit and miss problem, it doesn't like to idle at all, if you take your foot off the pedal then the power drops off more or less immediately.
I have changed distributor cap, rotor arm and spark plugs. It's just gone through the MOT 2 weeks ago so no notice then of emmissions problems.
Any other ideas as to what to change / check / alter or do i risk taking it to a toyota dealer and getting it professionally checked out ?
Suggestions ?
Cheers
Mark
Suggestions ?
Cheers
Mark
