215 65 R17 tires and wheels question
15K views 8 replies 4 participants last post by  oldhag
I want to order this package of studded winter tires for my wifes Rav4.
215/65R17 Firestone Winterforce tires
17x7.5 Sport Tuning T10 Machined w/Black Accent wheels.
Will the above tire and wheel combo fit on it?
Its a 2010 Rav4 V6 limited. It came with 225 65 R17.
#2 ·
Yup, that should fit. It'll be slightly smaller than stock so your speedo will read fast and you'll lose a little bit of ground clearance.
Are you sold on studding the tires? Have you seen this TireRack test that includes the Winterforce?
http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=123
Well, I decided to go with the Firestone Winterforce UV Studded tires. I went with the 215 65 17's due to availability. We just had them mounted on the factory 17 in alloys that came with the Rav.
It was impossible to find studded tires in 225 65 17, the size that came with the Rav.
We definitely need studs as we are in Alaska.
The tires look exactly the same from 225 to 215. They say that the 225 is 10 mm wider but it doesn't appear so and fit perfectly on the wheel.
#7 ·
They do call them "winter" tires now, as opposed to "snow" tires like in the past. Snow tires were often made of traditional tread compounds, but molded with deep, blocky treads and big open sipes. Old style snow tires would be better in snow than traditional tires, but were pretty hopeless on ice. Their tread compounds were a bit better than that in normal tires, but still hardened and became glassy as temps got to freezing and below.
Modern "winter" tires are made of two different types of tread compounds. The first one is sometimes called a "traditional" tread compound, and is a lot like the older compounds but better materials allow this rubber to stay pliable to much colder temperatures, well below zero degrees F. These compounds, combined with the ability to manufacture treads with numerous, intricate sipes, allows these tires to have much better levels of grip than the older "snow" tires. Tires that use these types of compounds can also be distinguished by higher speed ratings, by their capability to be studded, or are called "performance" winter tires. Examples of this type of tire would be the General Altimax Arctic and Firestone Winterforce.
The other type of winter tire tread compounds are the studless snow and ice type, which have a very porous, fast wearing tread compound that grips ice and snow incredibly well, providing practically studded tire levels of grip on ice. These will also always be advertised as "studless" winter tires. These tend to be more expensive than the other brand of winter tires. Examples of this would be the Bridgestone Blizzak and Dunlop Graspic.
There's also the mountain snowflake symbol that tire manufacturers are allowed to emboss into the sidewall. It represents a tire that has 10% better grip in snow and ice conditions than some standard, which means that many all-season tires that have more aggressive tread compounds and larger tread voids can achieve this, even though their performance is far from that of a real winter tire.
#8 ·
oldhag said:
I see winter wheels advertised, what's the difference?
The vast majority of the time, the winter wheels you see advertised are just a plain black steel wheel sized to match your vehicle. It is a basic and relatively inexpensive wheel that you won't be quite as concerned with the wear and tear of winter abuse. They also save you a lot of hassle and cost with mounting / dismounting each season.
A word of caution though, protect the vulnerable areas with a petroleum jelly or other rust protection, as the finish isn't always high quality.
