I was backing out wife's one year old Rav4 (2022) from the garage when another parked car in our driveway "suddenly jumped" in the way (mine - her old Highlander, and it's fine, of course). Attached is a picture of the result - crack in bumper cover (horizontal black surface), plus small gap between that part and the gray part below. I assume a body shop would charge a lot to replace the cover and paint. Looking for alternatives to at least try first.
1) To close the gap, it looks like I might be able to just sort out the tabs and push it on tighter, but I can't tell if the tabs I see go over or under the piece of metal underneath (or alternate over/under)? Does anyone know? Or is there a diagram somewhere? I can't see anything on the metal edge that the tabs catch onto. EDIT The tabs go over the piece of metal behind the cover. I can push it back together, and it's almost perfect, but two of the tabs are slightly bent and go UNDER the piece, so it doesn't sit flush in that area. Does anyone know how to remove the whole silver piece? If I can do that, I should be able to straighten the two bent tabs and get it back on properly. It's part 52453. It looks like it's only held on by one or two clips (part 75392Q) on each side, but I don't know if I can reach them without taking other parts of the bumper cover off. EDIT
2) For the crack, would I need to take the cover off to use a heat gun/blow dryer/hot water to try to get it to align better (it's sort of "tented" up, and I need to flatten it)? It's not clear how hard/complicated it is to remove. A black marker would probably cover the white. EDIT***If I can take the silver part off (see #1), I think I can heat the crack from the other side or below***EDIT
I don't need perfection, but I need better than it is or I have to shell out $$$ to a body shop.
