Hi, as mentioned in a couple of other posts, I've suspected fuel dilution. Oil results are back from the first change (7k on the Odo), and my suspicions were confirmed. Results attached. I'm not worried about the metals, or the dilution. It just means more frequent changes for me. I'm not going to make a stink with the dealer, it is what it is, and I'll manage it.
Symptoms:
I live on top of a very steep hill. I can't leave the house without ICE kicking in if the battery has anywhere near a full charge. To effectively use this car as an EV it almost always runs its warmup cycle every time I depart, but the engine is seldom used otherwise unless I'm on a trip beyond EV range. This creates a large # of short cycles on my engine. That's a weak spot for direct injection. (had the same issue on a Honda 1.5T that only took short trips).
Other thoughts:
Symptoms:
- Oil level rose on the dipstick (up nearly 1/2 quart from original delivery). I'm estimating the ICE had about 4k on it, the other 3k was EV miles. Relatively low mileage for an oil change.
- Oil smelled of fuel
Other thoughts:
- I'll be changing my oil well before the 10k intervals in the manual. If others have circumstances where ICE (very) often kicks in uncommanded (many threads about this) you might want to look into more frequent changes. If you smell the oil on your dipstick and it has a faint fuel smell, or your oil level is going up this is your signal.
- I suspect the dilution issue will reduce when the weather warms, and as the engine breaks in (ring seating is important for fuel dilution). This was first oil change on a brand new car, with all winter miles. That's about the worst possible scenario- I think it will get better.
