hi sorry but not much of a mechanic but i've been having issues with the drivers door lock on my toyota rav 4 from 2021. The lock starts working for a bit sometimes but then doesn't lock or unlock with the key fob, indoor switch or the key from outside. I've looked up some possible reasons and it could either be the actuator motor, bad wires or fuses. i don't think it's the actuator just because it starts working sometimes but i really don't know. any help would be appreciated and thanks for reading.
Not sure what you mean by some of your words:
1.. What do you mean by "starts working for a bit"? Either it locks and you hear a click/clunk, or it doesn't and you hear nothing. Only the power back door has a time between actuation and fully closed/locked.
2. What do you mean by "key from the outside"? Are you putting the mechanical key into the outside slot and turning the key to lock the door? Since there is a direct mechanical connection from the key insert slot to the lock mechanism, the only thing that will keep it from locking/unlocking is corrosion in the mechanism.
Change the battery in your key fob. A low battery can give the results you are experiencing.
Sometimes, if one of the doors is open, even slightly, the car will refuse to lock. Be sure all doors are closed tight.
Everything on the 5th generation RAV4 is run off a computer. There is no direct wires from the door lock buttons inside, and the door lock mechanism. Like wise, there is no direct wires from the radio signal receiver for the key to the door lock mechanism. For door locking/unlocking (and operating the windows, interior lights, etc) it is the "main body ECU". The main body ECU sends a message by the CAN BUS to the lock mechanism, directing it to unlock/lock.
