1 - 8 of 8 Posts
v6minitank
Discussion starter · #1 ·
Gidday, when removing the front hub for replacement, the axle nut thread got a bit damaged so looking for a replacement.
What I want to know is are they the same used on the 2nd gen RAV4s? There's no gen 3s at any dismantling yards that are open over the weekend. Cheers
I'd reuse it. The "damaged" spot at about 6 o'clock is where it was dimpled into the slot in the CV shaft to keep it from coming loose. You can use a punch to dimple it in again which may be in a new spot. Unless you break that spot out completely it will hold the nut on just fine.
When replacing the CV shaft replacement ones usually come with new nuts.
Forget looking at a parts yard since as Automender says ALL used ones will have the same indent.
Reactions: ravenuer
1 - 8 of 8 Posts
