Hi,
My RAV4 is extremely hard to start when warm. It's a RAV4 manufactured in Japan in 1995. Below are the details.
Engine: 3S-FE
Frame number: SXA-11
When I check the engine bay vacuum lines, I found that the fuel pressure regulator is connected directly without connecting through the default lines which runs below the inlet manifold. Could this be the cause for hard start when the engine is warm (does the heat of the engine has any effect to make the warm start easy when running through the default vacuum lines below the inlet manifold?)
Also I noticed that, it's missing the vacuum switching valve (VSV) shown on the diagram below. Does anyone know what is the purpose of the VSV. Could that be the reason for the issue?
Thank you very much!
Anu
Engine: 3S-FE
Anu
