81 - 100 of 233 Posts
I just DIY'ed this on my 2020 Rav4 Hybrid with 44K miles. The P/N for the valve with the short hose is 16260-F0021, around $80 shipped. Quick overview: remove upper hose by pulling back white clip. Wiggle short screwdriver into electrical connector and lift tab, then lift up on connector. Remove 12mm bolt to loosen adjacent check valve, and then remove 12mm bolt to remove the bypass valve from the bracket. Remove 10mm bolt holding 02 sensor wire guide, just to get it out of the way. Now climb on top of the engine, and using a pair of pliers compress the hose clamp on the block end of the hose. You can't see what you are doing, it's very awkward, and it took me around 30 tries, but it will come loose. Installation is easier, and follow Car Care Nut's instructions on putting then engine into maintenance mode for coolant system filling. Hopefully this will make my "Maintenance Required" warning to go away.
Have same problem "Engine Maintenance Required" Toyota RAV4 XLE 2020 at 38K mile. Went to dealership they said Cooling SYS concern CODE P26815 Coolant BYPASS VALVE SHORT TO BATTERY and that I need to replace coolant bypass valve $768.44. I asked if its ok to not replace it and drive, she said that it's ok but make sure to watch "H" symbol to not go up and that I need to change it when I have a chance. so I'm still driving and watching this H to not go up and it's not going up so I'm fine for now. Already 43K driving and it's fine. Please let me know if it really hurting my engine and i need to change it ASAP because I'm worry but don't want it ruin my engine.
It is OK to drive a RAV with a faulty coolant bypass valve. All it really does is to keep engine coolant from flowing through the heater when you have the A/C operating. Three things to watch out for: 1. Temp gauge-no overheating. 2. Visible coolant leaks from the valve if it is cracked (it is BEHIND the engine on the drivers side at the top.) 3.Keep coolant reservoir properly filled. If the RAV overheats, or the valve is actually leaking then STOP driving and get it fixed ASAP. Now I'm NOT saying that you should just keep driving and NEVER get the valve replaced. Obviously, when you can afford it and have the time get it fixed. There is always the chance the valve could crack open, or its internals clog up and that would be VERY BAD for your engine.
So, what I gather is that you can’t just replace the valve because it’s hard to get the hose back on and everyone is recommending to replace the whole assembly (with hoses)? I want to do it myself but seems as if I won’t be able to reach the shorter hose. I have a 2020 RAV4 and also “outside” of the warranty window. Dealership wants $900. I bought just the valve for $30.
Highly unlikely you will be able to just reuse all the original hoses and get them over the nipples on a new valve since the old hoses are PRESSED onto the faulty valve. You will need to buy some new rubber hose at a car parts store. Here's how a long time poster in this forum removed the shorter hose under the valve with a mirror.
Tazio Nuvolari
Do you think it is possible to cut the valve before the rubber pipe and then remove the PVC pipe from the valve that is in the pipe? Replace the valve and put a metal flange just before the valve.
Is this something that has been tried?
I don't know if you understand what I mean.
I'm unsure what you mean. If you bought the bare valve without the new hoses pre-installed. So to install it you need to get the pressed on bottom hose off the bottom nipple on the old valve. Since you are going to toss the faulty old valve anyway there are several things you can do. 1. One way is to try to heat the pressed on hose with a heat gun or hair dryer and twist it off the old valve--then try carefully to see if it will go over the new valve's nipple. I dont't think it will come off the old valve by heat alone but you may be lucky. If the hair dryer/heat gun won't loosen the hose enough then just try to pry it off with a screw driver . It doesn't matter if the old defective valve is damaged because you are pitching it anyway--but you want to keep the hose in useable condition. 2. If the hose just won't come off the old valve or fit over the nipple on the new valve, then you can cut the pressed on hose off the old valve and splice a new short section of hose into the cut old hose (which goes down to the T-fitting junction) with a brass barb and hose clamps and then connect that new short hose to the new valve's lower nipple using a hose clamp. Here is what the valve assembly looks like with the hoses pre-installed; the bottom nipple with the pressed on hose; the bare valve.
Currently I don't have the problem on my RAV4. I just understand……….
The question I have is why is it so difficult to remove the valve from the rubber tube.
Are the two pieces glued together?
On the RAV the bottom hose coming from the nipple on the valve is pressed on at the factory. I think it is heated and a form pressed over it to CRIMP it tightly around the nipple. There is no hose clamp. In contrast, on the Camrys and Corollas that same valve has a plain old hose that just slips over the nipple and a hose clamp holds it on.
Just copy/paste from useful sources:
Coolant Flow Valve,Engine
Tech Notes
Coolant Flow Valve may be called Water Valve, Flow Shutting Valve or Engine Coolant By-pass Valve in OEM information.
Operation
Coolant Flow Valve is part of Variable Cooling Control System that allows for quicker engine warm-up, heater efficiency, and engine efficiency by controlling coolant flow to various components under certain operating conditions.
Internal valve closes by spring pressure when engine not running. Coolant flow with running engine will open valve which remains open unless ECM energizes valve closing valve as long as ECM powers coil.
Coolant Flow Valve (under ECM control) can block or allow coolant to flow to heater and transmission assemblies:
1). All Coolant Flow Valves will be closed to promote early engine warm-up
2). Coolant Flow Valve for heater will open during engine warm-up to force quickly warming coolant to heater for maximum heater when engine cold.
3). All Coolant Flow Valves will be open, along with thermostat to reduce coolant temperature during periods of maximum engine demand.
4). Coolant Flow Valve for heater will be closed to provide for maximum A/C cooling.
Component Location:
Coolant Flow Valve for Heater:
At left rear valve cover area above exhaust manifold. Has heater hoses connected to valve.
Coolant Flow Valve for Auto Trans:
Mounted to Differential housing at front left hand inner axle area. Has heater hoses connected to valve.
Connector
View: Connector Side, Front Probing
Heater Coolant Flow Valve Connector
Pin Assignment​
Wire Color​
1=Coolant Flow Valve Control​
White​
2=Coolant Flow Valve Power​
Blue​
Auto Trans Coolant Flow Valve Connector
Pin Assignment​
Wire Color​
LtGreen​
Red​
Tests
DC Voltage Test
Disconnect valve connector.
Connect test leads:
=Known good ground
KOEO, voltage should be about 12.0V (battery voltage).
If not, check 10A EFI #1 fuse and wiring to canister vent valve.
Resistance Test
Inspect Coolant Flow Valve for open circuit.
Disconnect connector.
Connect test leads at valve side:
=Coolant Flow Valve Ground
Should measure about 22 to 28Ω at 68°F.
If no continuity exists, suspect faulty Valve.
If the A/C and heat is rarely or never used, can the bypass valve still fail? I'm at the mileage where most people's seems to fail.
Going in for a complete coolant replacement in January and was thinking of just having it replaced preemptively at the same time...
Yes. The valves crack or the internal spring and electrical circuit fail with no explanation, rhyme or reason. There is no "cause" or modus operandi of the failure other than a large per cent of these valves are simply defective.
The valves fail randomly and with no predominate mileage range at time of failure. I have read posts here and in ToyotaNation where coolant by pass valves failed at 23k and 25K miles. There are many posts where they fail at around 45--47K miles. There are many posts where they fail at 75K-90K miles. There are few posts where they fail above 100k miles. ALL the posters with very high mileage RAVs and 8th gen Camrys in the forums and on Reddit Rav4 Club that I questioned reported that their valves NEVER failed! Also, I think we would have seen a flood of reported failures if these valves were like the 2019-2021 roof leak fiasco or the hybrid big wire corrosion issue--so I think that most or a least a majority of the valves are OK and NOT defective--but the defect % is high.
I really don't think preemptive bypass valve replacement is a good idea. It's literally a crap shoot or spin of the roulette wheel whether any given bypass valve is defective or will fail and when. That new valve you preemptively install could fail next year but your old one may have lasted 5 more years! There is no way to tell and the cost of the valve and installation is expensive. Obviously, they ALL will eventually fail like any car part --the issue is when.
Yea guess I'll just wait, hopefully Toyota is able to make an improved version in the future but I doubt it w/ the new generation RAV around the corner.
I think if they just made it out of cheap zinc alloy pot metal instead of plastic it would have been better. Also they really could have put the darn thing in a different location in the engine compartment where it would have been quicker, easier and a simple DIY job to replace. They could have used longer hoses and hose clamps instead of pressed on fittings.
