21 - 40 of 41 Posts
Correct. All you have to do is check the sticker located on the driver's side door jamb. My 2020 Rav4 limited was NiMH, but my new 2024 limited has the Lithium Ion battery.
My drivers door jam does not say what kind of battery I have. However, there is a sticker on the engine hood that says I have a Li-Ion battery.
I think only the Rav4 Prime Battery has climate control. From what little I have seen with the other hybrids, there are only fans for the smaller packs, not much else.
What would it take to convert the 5th gen rav from nickel to lithium? Are the battery box exteriors similar? Is it a separate controller? Would you need a new ICM or something?
Tell me what you know please.
Your question is useless. Like many explained to you it will require tons of hardware and software swap. Total price will probably be higher than your RAV4 is worth. Just leave it alone. Toyota never planned for idiots to tamper with its batteries.
Prime has HVAC tubing routed through the battery… so if your AC goes out you might not want to drive in EV (At least for more than a few miles at an time) until it is fixed.
Discussion starter · #30 ·
middle finger to you bud. It is a hypothetical question I asked with no follow up. Obviously I realize its not plausible.
Charging regimens for lithium vs NiMH are completely different, so whatever module controls the charging function and monitors all the sensors would have to be changed also. It depends how far into the rest of the car the battery type impacts, especially wire harnesses. I doubt anybody on this forum has access to all the details needed to determine the feasibility of a battery chemistry change.
Correct.
Probably nothing with the wire harness as the voltages and currents aren't different enough to require wire/connector changes.
Lithium requires more monitoring per module than NiMH so the harness and BMS are different. Toyota almost never puts in extra wires or connectors for factory options or different configurations.
With that said, Prius gen2s and gen3s have an aftermarket vendor for lithium. But the bms can’t be modified so there are no additional temperature sensors for the aftermarket lithium. Failures are frequent and early including some that have filled the car with smoke.
Better to buy a Rav with factory lithium.
Well companies offer Lithium upgrades in the previous gen RAV4, so it's coming.
As I said useless
Is he asking useless question? Or are you just another naysayers giving a useless answer cause you dont know anything?
21 - 40 of 41 Posts
