I need to replace tie rods which will require an alignment after it's done. I'm wondering if I should go ahead and do struts at the same time.
The deciding factor is probably whether an alignment is needed when replacing struts. If so then I'll probably do it now to avoid having to do the alignment for a second time in the not too distant future. The original struts seem to still be OK but with 75,000 miles on the car I expect they'll need to be changed sooner than later.
Then again I just had to change the water pump which was not cheap, and I'd prefer not to have to do everything at once if it's not necessary. Decisions!
