Loss of power
1 reading
16K views 3 replies 4 participants last post by  Sensei
I recently bought 2002 nv model and from the outset have had loss of power problems.
Driving home on motorway after picking it up had to pull over due to loss of power. Rang garage who said it was due to being really low on diesel when I picked it up (I filled up as soon as I picked it up)!
Had problems ever since, been to 4 garages and sent it back to garage I bought it from and they have fitted air flow meter, fuel filter and another part I forgot that one (sorry dumb blonde)! Finally thought it was sorted after last part fitted but next day it started again!!!!!!!!!!
Just suddenly loses powere while driving along and when I turn off and start again it usually is ok for a while (till next time).
Anyone any ideas please, its driving me crazy (and its dangerous on motorway!!)
Someone suggested turbo sensor??
#3 ·
With my Smart Convertible i had likewise issues. There it was after some testing clearly a pressure tube as well as the turbo pressure sensor which malfunctioned. I had to stop in full and restart the engine. The engineer at my repair shop told me that i could also put the transmission in free, switch off the car and switch it on, then get into gear again and drive on. Haven't tested that, but he said it could work in a difficult situation of having no place to stop for instance.
That sensor was costly (75 euro (105 dollar) for a sensor which isn't even as big as your thumb) but replacing both parts was done within 2 minutes.
The turbo pressure sensor detects overpressured turbo and blows off the high pressure. If it malfunctions the engine automatically switches to safe drive out mode, which means only a fraction of the power of the engine remains to get you to stop at a safe spot. To prevent the engine to blow out of the hood of the car.
Greetz
Pim
Might be the SCV valves acting up. This seems to be very common on RAV4.2 D4D. Read more about it here: http://www.toyotaownersclub.com/forums/index.php?showtopic=87986
If there are any fault codes stored (check engine-light should light up when they are stored), get a garage to read them for you (or do it yourself) and look them up. If they are related to the SCV-valves that is most likely the problem.
