Hi there,
I have a 2009 Rav4 Base Model V6 4WD. It has the towing package, and a factory Toyota trailer hitch and wiring harness. Here is the part number for the wiring harness: 08921-42900.
This part is a kit containing the interior and exterior wires needed. The exterior wire is a 2 foot 4-wire assembly that contains the 4-flat trailer connector, and a connector to plug into the interior wiring harness.
This brouchure: ( www (dot) rav4world (dot) com/pdf/2006/06_trailer_wire_harness.pdf) (my first post, sorry, I had to make the URL un-clickable) has the installation instructions, and if you page down to page 4, there's a diagram showing "SUB WIRING HARNESS NO. 1" at the back end of the vehicle.
I am wondering if that part (sub wiring harness no. 1) is available separately from the entire wiring harness kit. The entire kit is more than $100. I don't need all of that, but the 4-flat connector has a lot of corrosion, and I would like to replace it.
Please let me know your thoughts on this. Thank you!
Doug H
Doug H
