Passenger Side Mirror Replacement
1 reading
6.4K views 4 replies 5 participants last post by  Avisitor
My passenger side mirror got banged causing it to bend in, sending the glass flying, breaking. This white part also popped out and broke. I can’t seem to find a name/number to order it separately. The rest of the mirror/casing is in tact minus the glass itself and was hoping I could just replace myself.
Any ideas on what this is called? (Yes, I googled all the numbers printed on it and even reverse image searched it.)
TIA for the help.
#2 · (Edited)
#3 ·
It has the convex blind spot mirror in the corner.
Those are the standard mirrors that came on my '18 LE. I think they are fantastic !!! How the govt could mandate those stupid TPMS sensors, but not something as actually useful as this is beyond me. I'm amazed you don't see these as standard equipment more often.
Edit - the official Toyota Parts website is handy for locating part #'s
#5 · (Edited)
The white piece actually is screwed in with a metal washer and a plastic washer. The part that has those wobbly extensions snap onto the motor. Then the washer with the screw go in. Must be aligned correctly for the remote to position the mirror.
Before you try buying a new piece, have you tried reinstalling this piece since it doesn't look damaged from the picture. If you do need to replace it then I would be looking for the entire side view mirror. I know it is more expensive. But, you would be happier if the mirror doesn't fall out if that piece was damaged.
Note: Replacement mirrors don't always snap in easily. I just replaced mine with heated mirrors. The mirror just wouldn't push on. Had to open the clips on the mirror for it to snap on.
Edit: Just looked at picture again. The center of the piece is broken. There will be no way to screw that piece in. You will need a new piece. Still believe a whole new side view mirror would be best. Don't know what other damage the mirror might have absorbed. Good luck.
