I’ve owned a RAV4 Prime now for nine months and I thought I had a pretty good understanding of how it works (I was wrong). I was doing some on line research trying to understand AC to DC conversion efficiencies. I was trying to find out what kind of Power Factor Converter (PFC) is used in the RAV4 Prime EV Charger Assembly. I actually have not been able to find out. But as I have been looking, I ran across this Toyota Service Manual titled RAV4 Prime Hybrid Vehicle Dismantling Manual. The purpose of this manual is to provide guidance “to educate and assist dismantlers in the safe handling of Toyota RAV4 PRIME”. In other words, if a RAV4 Prime is totaled in a crash, this manual provides guidance to technicians to safely dismantle handle high voltage components.
The manual is found at the following link https://www.toyota-tech.eu/HYBRID/HVDM/EN/hvdm RAV PHV.pdf
I found the first 13 pages (the “educate” section) to be a fascinating summary of how the RAV4 Prime works. Main points I learned are:
You learn something new every day.
- The HV battery pack consists of 96 low voltage (3.7 Volts) Li-ion battery cells connected in series to produce approximately 355.2 Volts DC.
- To power the car in EV mode, the 355 DC battery voltage goes to an inverter/converter to be converted to 650 volts DC. Then this 650v DC inverted to 3-phase 650 volt AC to power the motors.
- The two electric motor/generators (one front and one rear) power the car with 650V 3-phase AC power. (The "generator" part is the Regenerative Braking. When you take your foot off the accelerator, the car coasting still turns the motor which allows it to be a generator which recharges the battery. This generator mode provides resistance which slows the car down.)
- The cars electric generator is a 650v three phase AC generator. This generator powers the electric motors or charges the battery through the Inverter/Converter.
- There is a 350v DC to 14v DC converter to drive the drive the cars 12v DC electrical systems and change rear 12v battery.
- The cars Air Conditioning runs using a 355V DC compressor.
