Water leaking through fresh air intake
Tags
water leak
6.2K views 6 replies 4 participants last post by  krammin1
First post here, sorry if in wrong area. I have a 2010. Water is leaking on to my passenger floor board. After some hose testing I found the source of the leak. Picture below is the source of the leak. The orange rectangle is where the cabin filter goes. The red arrow is pointing at the fresh air intake cover. The blue circle is where the water is dripping (the corner of the hinge of the fresh air intake cover). Does anyone know a solution? Dealer wants to replace the motor that controls the fresh air intake cover (which does not work), but I can't imagine that would actually fix the leak and they want to charge $1,000 to do it. Any advice would be greatly appreciated.
#2 ·
Your drain hose may be plugged up. Run a thin wire or string trimmer line through it.
#7 ·
Here’s the TSB for the cowl leak:
Thank you!
