According to the (poorly written) manual, S-FLOW stands for "Front Seat concentrated airflow mode" and is described as the following:
This function automatically controls the air conditioning airflow so that priority is given to the front seats. When the front passenger seat is not occupied, airflow may switch to only the driver’s seat. Unnecessary air conditioning is suppressed, contributing to increased fuel efficiency.
Front seat concentrated airflow mode operates in the following situations.
No passengers are detected in the rear seats
The windshield defogger is not operating
While operating,
illuminates.
■Manually turning front seat concentrated airflow mode on/off
In front seat concentrated airflow mode, directing airflow to the front seats only and to all
seats can be switched via switch operation. When the mode has been switched manually, automatic airflow control stops operating.
Press on the air conditioning operation panel and switch the airflow.
Indicator illuminated: Airflow to the front seats only
Indicator off: Airflow to all the seats
■Operation of automatic airflow control
●In order to maintain a comfortable interior, airflow may be directed to seats without passengers immediately after the hybrid system is started and at other times depending on the outside temperature.
●After the hybrid system is started, if passengers move around inside or enter/exit the vehicle, the system cannot accurately detect the presence of passengers and automatic airflow control will not operate.
■Operation of manual airflow control
Even if the function is manually switched to directing airflow to only the front seats, when a rear seat is occupied, it may automatically direct airflow to all seats.
■To return to automatic airflow control
1 With the indicator off, turn the power switch off.
2 After 60 minutes or more elapse, turn the power switch to ON.
