For the past 3 months, I am hearing a drone whenever I press the accelerator. It does matter which gear or rpm. As soon as you leave it, the drone stops.
With my winter tires now on, that noise is camouflaged but I can still decypher it.
What's the most probable culprit? A hole in the muffler? the CAT?
I was planning to do a transmission filter change followed by a drain/refill of ATF but with the cold weather already here this might have to wait until winter. But my gut feeling is that it is not the transmission.
In the past 2 years, I have changed the transmission fluid ( 2 drain/refills) as well as the rear differential and transaxle lube.
My RAV has 42K miles.
