Odd Transmission Behavior in Cold Weather
25K views 21 replies 17 participants last post by  MP3_E46
#1 · (Edited)
Lately the weather has been become quite cold. By cold, I mean colder than -25 C (or -13 F)!
Just wondering if anyone else has been experiencing the transmission acting strange in colder weather. It seems like it stays stuck in first gear and revs higher than normal (more than 2,200 rpm) just to reach 20 km/h (or 12 mph).
This only happens in extremely cold conditions and the problem goes away once it has warmed up after about 8 minutes. I do not have a remote starter, so my usual warm up time is 2-3 minutes in extreme cold.
I have driven other vehicles in these conditions and none of them behaved this way.
This is a 2014 RAV4 built in Canada, AWD, 6-speed auto that has about 12,000 km (or 7,500 miles) on it.
Edit: Added video
#2 ·
It sounds to me the car is trying to warm up the engine faster because of the cold ambient temperature. The computer revs the engine higher so it creates more heat. Probably normal.
I'm adding a video to this post so it's more clear what I'm talking about. This was recorded while on a pretty flat parking lot. Does it seem like there is slipping? And that's supposed to be normal?
first gear in cold - YouTube
Have your Toyota dealer check the transmission fluid level. Just make sure the level is normal at the operating temperature.
#5 ·
It was -14F here the other morning and I didn't notice any higher revs to change gears. However, I do let the engine warm up till that bar moves at least one spot before driving. Yours is still all the way to the left. And I always drive in sport mode which normally keeps the car in a lower gear for longer anyway, so I might not have noticed.
Like others have said it does seem normal that the car is trying to warm itself up.
Does it go away once the car warms up?
#9 ·
at -25 my body doesn't work properly either, oh well !
two days ago i left the house @ -5 F, other than normal cold engine noises and taking 7 miles to reach normal temps
probably the engine/ trans management comp just doing it's thing
my kia sorento had the delayed trans shift syndrome in - F temps only
#11 ·
My 2013 AWD also does the first-gear-hold thing when below zero.
But...
Last week I had to gun it once due to traffic, and to my surprise it started shifting normally after that. Even though it was still not warmed up...
Which makes me think it's something viscous clogging in the transmission, and not a shift design feature.
The burst of energy freed up whatever was clogged.
#14 ·
WS fluid works well even in -35F. I am talking from experience.
On the other hand, any ATF change (OEM or non-OEM), even at 30K miles, will surely make your transmission shift better. That does not necessarily mean that non-OEM is better than OEM.
Redline, AMSoil, ... all make great fluids. I don't know if they are better than WS.
#17 ·
It's was -25 Celsius yesterday and had the same thing happen, really weird.
I also have a Yaris so I'm use to feeling a cold tranny shifting slowly and holding onto the lower gears a bit longer, but this thing with the RAV4 tranny feels like a gear that's even lower than first. It definitely wasn't a case of it staying in 1st gear too long.
Over 2000 rpm and only 5-10 km/hr. I pull over, let it warm up another couple minutes, slowly pull away again, revs up, a little better this time, then about 30 seconds later it seems to find the real first gear, then slowly shift to second. Then it starts behaving normal.
Waited again until today, it's -15 Celsius, does the same thing.
Honestly though, this has been our first winter with this new RAV and these past few days have been the coldest so far, scary cold in fact.
#21 ·
I am using Valcoline Maxlife (synthetic) on mine here in Ontario and my transmission is shifting fine even on the coldest days. Performance wise synthetic can achieve better results in either freezing or hot weather. I use synthetic gear oil (Mobile 1) on my transfer case and rear differential also.
#22 ·
100% Redline D6 in my 2015 2WD RAV4 since 24,229 miles here (~36K miles now) and it revs high often when cold.
Almost certainly it's staying in fluid coupling mode (delaying AT lock-up). As other have said this is to warm the fluid faster and protect gearboxes.
Why some cars do it more than other I've no idea. Also the computer does not know what I fluid I have in there, so that's almost certainly a red herring.
