41 - 60 of 87 Posts
any issues with phone calls and your voice sounding low? I didn't install the microphone that came with the unit like @kkfree00 said but not sure I need to do that since my voice is coming across sounding low to the other person on phone calls.
anyone having that issue? or did anyone install the microphone and use it? thanks
Discussion starter · #43 ·
Hi Guys,I bought 2022 rav4 hybrid xle and ordered the same one that kkfree00 ordered. It worked! I am totally new for installing head unit and thank you so much for your help kkfree00. It's not easy for me, but eventually figure it out by doing it patiencely.
Does remote connect app working after installing this unit ? I mean can you remotely start the car with app now ?
I tested it before I close the cover, it worked well without the microphone
It worked good without the microphone.
Hi, I just wana update some of the issue of this head unit:
1. the reverse camera is sometime glitch once when driving. it will not cause nav issue but
2. the navigation sometime showing bad resolution when driving. not sure if this is related to first issue, when switch back and forth it return normal.
I checked some link like this below but still don't know what cause first issue. One of the user has same issue but different head unit. I guess that's only for 2022 rav4, can some one post a video if you had same issue? I gona reply to seller to see if they can find out what's the issue of this.
The below link just reference
Ive ordered the same unit. It looks more complicated than I expected. Any tips or anything I should know before install. Thanks
How is the display laggy when moving around or pretty smooth? Can someone post a video of the display?
Those images are helpful. I was worried about all the connectors that did not have anything plugged in. e.g. the 5g/Wi-Fi, green port above it, coaxial, between the usb/AV port. Do those stay empty or are there corresponding connectors from the car? What about the single wires for brake and the like? Do I just splice those in? Is it obvious where?
Ive got the 2022 Limited, will report back what does/doesn’t work after I manage to get everything hooked up. My main concern is the 360 view, cross traffic alert, things like that.
Hi guys I really need help. I bought this screen from Ali express but I can figure out how I can mount it. There is no hooks to mount on this device. Can you guys please put some input ? I am not sure if this is even right screen
Thanks
US $343.35 37% Off | 12.3inch Android 12 Screen For Toyota RAV4 Prime XSE 2021 2022 Car Multimedia Video Player GPS Navigation Radio Carplay HeadUnit
How is the light glare from the sun on your screen? That was a huge issue for me with my old 2017 model. I want to upgrade it on my 21 xle model, but that is super bothersome when driving
hi guys
I recently purchased a Rav4 2022 xle premium
I really dislike the current head unit style, so I decided to find something that fits this vehicle
Do you have any suggestions?
i find a product on AliExpress that looks very nice, but I am not sure what features will be lost by installing it. Is there anyone that already has this product ?
here is the 👉 Link
Update?
41 - 60 of 87 Posts
