i have a 2019 XLE and just noticed it uses 0W16 oil. I went to 3 auto parts stores and they never heard of it. Is this something new or can 0W20 be used?
Ah no. 10%. It needs to be measure on a long trip not in the city driving. On my oil I was getting 44-46 mpg or more while on the dealer's oil I barely got 38-40 mpg. Maybe less. How do you think I found out? And why do you think I made them to remove the oil and use my own?~.5% mpg improvement with each thinner grade
So, I'm not worried about oil for best fuel economy. It is sad that Toyota doesn't provide an oil for least amount of wear. And, I'm not in a cold enough climate to worry about cold harder to starts.
0.5% of 40mpg is literally nothing. 1% is literally nothing. That is 0.4 mpg. It would fall under the margin of error. Not much fuel savings. No one in the right mind would be buying thinner oils because something like 0w-20 is not only widely available but also widely discounted. You can find 0w-20 in every store at a discount. Like Costco for example. They even have it under Kirkland brand. 0w-16 is only available at chain stores and Walmart but only a few brands and not often discounted. I have seen sales on 0w-16 twice in 2 years and not by much.I remember reading about an epa test many years ago and the results were the .5% or close to it if I recall, or not much.
The idea was to have the entire population using it and saving all that fuel.
The only way to make that happen was to provide an incentive to the manufacturers and print it on the oil filler caps.
Myself am a little paranoid since my last car had stuck rings after the previous owner having dealer oil changes for 70k.
Oh, they do in the quart size but those are for sale at the parts counter. At the shop they use is 0w-20 in the barrels and use a special gun to put it in the car. It is much faster because this gun is programmed for the quantity. The whole oil fill process sucks. They don't wait for the oil to completely drip out so it usually end up overfilled. I saw it with my own eyes and will never go back to dealer oil change, not even for a free one.I can't argue the points of which engine oil are best to use, but find it strange that Toyota dealerships don't have access to 0W16 oil considering the RAV4 is the best selling vehicle in NA. They are selling you the vehicle but can't service it correctly according to manufacturers specs.
Good for you. I have not seen these papers and most likely neither have you. The thing is I actually ran many tests while all you have is your word. BTW, EPA says that my car only gets 38mpg combined. I am getting way more than that. And many, many others are getting way more than that. As high as 65mpg.There are plenty of SAE papers on the .5% fuel improvement with thinner oil.
I'd believe SAE before I believe some of the members here.
