3 1/2 years ago I published a post on the now famous "CableGate: issue:
CableGate Post # 507 In that post I stated that I used CRC Heavy Duty Corrosion Inhibitor and Permatex Dielectric Grease. This is what the connector looks like today:
Note the 2 holes in the bottom of the orange connector cover. The next picture is the connector with the orange cover removed:
Other than the dirt, the metal braid around the 3 wires looks just like it did 3 1/2 years ago.
Please Note, the discoloration of the braid and the metal clamp around the connector is not corrosion, it is CRC Corrosion Inhibitor.
After a light spray of mineral spirits to remove the dirt that had accumulated the past 3 1/2 years (and letting it dry, I sprayed the braid with another 3 light coats of CRC Corrosion Inhibitor. The connector was attached to the motor (again using a little Permatex silicone grease.
Note that the orange plastic cover does not fit tight around the metal connector. This allows dirt and water to enter the connector - which is probably the root of the corrosion problem.
Keith
