Inverter Coolant Top Off - Evaporation, Leak, or Normal?
4.8K views 3 replies 4 participants last post by  NameofUser
I have a 2019 XSE with 34K miles. The last time I checked the coolant levels was around 20K after dealer performed complimentary service. I did my own oil change at 30K miles but didn't check at that time. You don't have to tell me, I'm a horrible person I know.
Fast forward to yesterday I opened the hood and found the regular coolant level was fine, but the smaller inverter reservoir was at the LOW level. Toyota Service Dept. was closed yesterday and today so I couldn't buy their OE 50/50 Pre-Diluted Super Long Life Coolant. I went to a local NAPA and bought Zerex Valvoline Asian Vehicle Anti-Freeze Coolant and topped off.
My question is, is it normal to lose that much inverter coolant in 14K miles? I live in SoCal where it's warm, but that sounds like a lot of evap. I didn't notice any leaking but will definitely monitor it going forward. My MPG has been low for a Hybrid (33-35) but I always attributed that to the hills and inclines where I live (+ flow of traffic freeway speeds). I've also noticed ICE being on more frequently in the last few months. Should I be concerned about any potential damage or issues?
You know that is an overflow tank, so even at the low level there is plenty in there as long as it is above the hose, you should have waited to get the real coolant.
Sadly OP does not know.
You should really never need to top off inverter or radiator reservoirs if filled to proper levels and over course of coolant maintenance schedule:
10yr/100k 1st drain/fill,
then every 5yr/50k mile drain/fill
if you do, there may be a leak, or another problem in cooling system. The BEST check for radiator coolant level is to revove the radiator cap and verify the coolant is to the top. Checking the radiator overflow wont tell you there is a problem at the radiator, esp if there is lack of vacuum (the overflow will remain unchanged, but level in radiator will be low). Remove radiator cap when the car has cooled sufficiently (many hours or overnight).
