Plastic Shields
873 views 8 replies 5 participants last post by  teacherdude
The plastic tray had two clips break & fall off due to some ice getting stuck.
What is the correct size/part # for both of the missing pins? They are located on the passenger side of the car. I have attached two pictures below.
My options are this:
#1: Preferably buy the pins off of Toyota website (please include link if you know the part/number & sizes)
2#: Use generic clips from an auto parts store (still need to know correct size)
3#: Use zipties (would be last resort for me if the other two options don't work out).
#2 ·
At toyota or even the parts store, those pins will run you about $5 each. Instead I keep one of the Amazon bulk packs handy. They run about $10 for a decent sized set. You'll find that you probably have a bunch of missing ones all over your car.
As for the size, pull one of the other pins to confirm amd measure. I think there are 2 different size pins that are used to secure the splash shield.
To remove use a small screw driver and pry out the center expander portion of the pin. Then pull the pin.
