As some you may know, I recently changed my steering wheel. I replaced my 2008 Base with a 2010 Limited. The steering wheel was well centered with my original 2008.
http://www.rav4world.com/forums/98-4-3-interior/90787-diy-adding-steering.html
When I was putting the 2010 Limited steering wheel on, I noticed that I was not able to get it aligned perfectly in the middle. It could put it either slightly to the left or slightly to the right.
Is there something that I could change (may be in the steering wheel rack) that you let me make this small adjustment?
I called an Alignment shop where I have a coupon and their take was that the SW can only go one way. I know this is not true. It can be adjusted in increments of approximately 5 degrees. Now that does not give me confidence in the abilities of this shop.
Would it be ok if they centered the 2010 SW and made a regular 4-wheel alignment? What about the SW angle sensor? Should they reset that too? If my SW angle sensor is slightly off, would the VSC light be on?
I don't want VSC/traction control to be messed up, especially for my winter driving.
