Just had a set of Firestone Destination LE2 installed with alignment on my 2010 RAV4 Sport. I think Firestone recommends 32 PSI. Is there a problem with 35 PSI in an effort to increase the MPG? All suggestions and ideas welcome.
The most comprehensive information I have found is from JuneBug's reference to this. Scroll down.Just had a set of Firestone Destination LE2 installed with alignment on my 2010 RAV4 Sport. I think Firestone recommends 32 PSI. Is there a problem with 35 PSI in an effort to increase the MPG? All suggestions and ideas welcome.![]()
The Accura gauge is still available from the manufacturer's web site. I have corrected the link.The most comprehensive information I have found is from JuneBug's reference to this. Scroll down.
Back and forth, pro/con at this link. The ultimate tire gauge mentioned is unobtanium now. Skepticism is warranted.
Maybe I'm just not understanding the chart. If my "reverse" calculations are correct, it means to set your tires 4 PSI higher than your desired 34 PSI would mean that you are setting them in a garage that is 25° C warmer than the outdoor temperature. I know you love your RAV , but I have never heard you mention that you keep it indoors with you before.I am using 34 psi on my no-name brand meter/compressor. From this chart, it seems I should be running 38.
In your area having a firmer tire helps to keep sidewall temperatures cooler, and should result in longer sidewall life.35 seems like the best all around for our RAVs but we don't deal with severe winter temps
Pretty much same for me. I run with 36 and getting very even tire wear. Was using 32 prior for long time, can't really tell much ride quality difference. Hey! It's a RAV!!@35 psi I notice no irregular center tread wear. The ride difference from 32 to 35 is, well, none.....it's still harsh on our pock marked streets down here regardless.
