Has anybody actually compared the updated design piston and piston rings of the 2az-fe to see if there's any difference?
Have they actually changed anything or does the car just seem fixed after replacement since the pistons are free of sludge?
Trying to decide if it's worth fixing my rav4.
The Toyota fix is no fix at all.
You post is very important: this is a technical issue so I have a long response. I went as hard as possible trying to find the answer and could not find it. The cause is gumming up and blockage of the oil rings and oil drain holes.
(a) I followed all the part number changes for pistons through 2001 to 2018 trying to find the defective pistons. I have seen no side by side comparison of the defective versus "corrected" types, except one suggestion by a youtube commenter that the defective pistons have a notch under the oil ring. This notch was introduced when oil squirters were added. Many performance pistons have such notches, so it is an unlikely cause. Even the Toyota tech guy (car care nut) on you tube could not show the difference in his video on the oil problem.
(b) I followed the low tension ring story (low tension to decrease friction and improve milage). No direct comparison between standard tension and low tension rings is available. I could find no standard tension rings for the 2AZ-FE and there is no tension information on performance rings, such as Wiseco.
I followed production sites, originally thinking that only Kentucky pistons were defective. Kentucky made standard size "B" pistons but the other sizes (A, C and D) came from Japan for US made engines. These different piston sizes are not the cylinder bore size, but refer to accomodating variation in the crank manufacture to save cranks that are out of spec. 95% of pistons are B, so rare engines have a mix of types.
(c) I followed up on US-made versus Japanese, hoping that only US were defective. The oil problem happens at a low rate in all 2AZ-FE regardless of where they were made. The 1AZ-FE has the same pistons and can have the same problem, but was not included in the US TSB (a recall that is not a recall and only in the US).
(d) Oil change interval, synthetic or non-synthetic: no consistent outcome came from this investigation. Some who adhered strictly to the rules had trouble, others who abused their engines with dino oil and long intervals had no trouble. Anecdotal reports of seafoam and other additives having positive effects suffer from reporting bias.
(e) Oil drain holes: number, diameter of hole and angle of hole in piston. I have seen claims that this is part of the new design, but I cannot find a direct comparison that verifies this claim. A proper technical paper should be published if this is the case.
(f) Piston heat hypothesis: it is claimed that the 2AZ pistons run hotter than planned. Compared to the 1AZ, with more fuel, the 2AZ will produce more heat with essentially the same cooling system. The 1AZ does not have the donut oil cooler that was added to the 2AZ. I also think people drive the 2AZ differently: having driven both the 2AZ is more satisfying with the low end torque. Its more fun to lead-foot the 2AZ.
It seems convincing that the notorious head bolt problem is caused by a foam insulator between the block and the plastic intake manifold, causing excess heat. Cooling is clearly an issue. In 2006 oil squirters were introduced to aid cooling as well as an insert in the water jacket to direct the coolant differently. As far as I can tell, these inserts and squirters are absent in 1AZ and 2AZ prior to 2006. Excess heat causing oil gumming could be a cause of a sporadic problem. Toyota tech scientists should publish their data. Small defects in cooling system maintenance might be a cause.
(g) PCV valve and carbon. Oil vapour from crankcase ventilation leads to carbonising of intake valves and piston heads. A bore scope camera down the spark plug tube shows carbon on most piston heads. There is no harm and maybe great benefit from adding a catch can between the PCV valve and the intake manifold. It should have been standard. It is notable that the new 2AR-FE has a built in oil separator (basically a catch can), so Toyota agrees.
Conclusion. I eventually reached the conclusion that the Toyota fix is no fix at all. Just imagine, if you replaced the gummed up old pistons with brand new pistons of exactly the same design what would happen? The engine would be returned to normal and you would have at least 100k miles before the problem might come back. This puts you way out of warranty and one step closer to the junk yard and no longer Toyota's problem. Since I cannot find any reasonable design explanation, that should be all over the internet, this is the only sensible conclusion.
Are there super redesigned pistons? Probably not, since even Toyota wont show us the difference. If your engine is burning oil, then get new pistons. Add an aftermarket oil cooler, keep coolant levels up and get rid of any air in the cooling system.
