i have a 2019 XLE and just noticed it uses 0W16 oil. I went to 3 auto parts stores and they never heard of it. Is this something new or can 0W20 be used?
You keep the same "winter" weight (in this case 0W) and increase the normal operating temperature viscosity; for that there are plenty of options readily available, all the way up to 0w-40.As I understand it, in hybrid engines, the oil is cold, which is bad, and so that there is no increased wear, such oil is used. Another thing is when the temperature is high, what then to do?
Yes, I think this is the right decision. Winter 0W-16, summer 0W-20 or 0W-30You keep the same "winter" weight (in this case 0W) and increase the normal operating temperature viscosity; for that there are plenty of options readily available, all the way up to 0w-40.
0-20 is a-ok, as is 5-30. But, you can go 0-20 on every fill if the 0-16 you wanted is not there. 0-16, 0-20 is just gonna be for fuel saving reasons. 0-16, 0-20, 5-30 will all protect the engine just fine. If perhaps you live where it get's to 0F or below, then run with a 0i have a 2019 XLE and just noticed it uses 0W16 oil. I went to 3 auto parts stores and they never heard of it. Is this something new or can 0W20 be used?
Don't even need a 0. The 5-30 for summer is a-ok. If you live in say hot TX, a 10-30 works, even a 5-40 would work a-ok.Yes, I think this is the right decision. Winter 0W-16, summer 0W-20 or 0W-30
In hot weather, hard acceleration 0W-16 is a bad idea.
You’re going to upset a lot of people with this comment 😂0-20 is a-ok, as is 5-30. But, you can go 0-20 on every fill if the 0-16 you wanted is not there. 0-16, 0-20 is just gonna be for fuel saving reasons. 0-16, 0-20, 5-30 will all protect the engine just fine. If perhaps you live where it get's to 0F or below, then run with a 0
There are a few engines out there that need the newly formulated oils (6B or "SN-PLUS" oils) for other reasons beyond lubrication, the Rav4 engine is not one of them.
I run a 5-30 365d/year. My winter temps don't go below about 29F.
Probably so, but I know how the oil works.You’re going to upset a lot of people with this comment 😂
use of 0-16 and 0-20 (over other usable grades) are based on 1) meets lubrication needs, and 2) used for fuel saving purposes.I've been using 0w20 for the past 75000 miles in my 2020 xle I live in Florida hot temperatures. People just don't understand that Toyota recommendations is based on moderate climate regions not 100+ summers.
Just run with whatever oil you want. No one else cares what you use except a few other anonymous self-proclaimed lubrication experts that parrot the same oil "facts" over and over again.Show me in the manual where it says a higher viscosity may damage the engine and even recommended a higher viscosity under more extreme conditions for better engine protection. There recommendation is for better fuel economy which they are required to meet. In warmer climates you never need 0 weight oil but it would.
Fixed it there. Once the consumer gets it, all bets are off because the shelves and internet are full of choices.Show me in the manual where it says a higher viscosity may damage the engine and even recommended a higher viscosity under more extreme conditions for better engine protection. There recommendation is for better fuel economy which they are required tomeetcertify to. In warmer climates you never need 0 weight oil but it would.
The difference in efficiency from 0w-16 to 0w-20 is negligible. Driving habits are always going to have the biggest impact. Toyota’s usage for 0w-16 is fueled by fleet efficiency and CAFE standards.I ran 0w 20 last summer and am running it this summer In my '19 LE. Got great gas mileage then and getting it now. Pretty much always above 35 mpg and often 39, 40, sometimes 41. Last summer got around 39 or 40 mpg on 200 mile road trip. I do run higher tire pressures than the door pillar states, like 38 psi, I expect that helps, and still under max pressure on tire.
Why would I run 0w-16 during the hot months to wring out a pittance of extra mpg? Of course, with gas just now hitting $5/gal in VA, maybe I could be persuaded to change my mind. Nah, not likely... I'll probably have to start walking everywhere I go soon.![]()
A poor attempt at mockery and trolling.I use whatever oil is on sale. Usually 5w-30. Always getting 40+ mpg. I'm not worried about CAFE standards, what the OM says, or the engine wear caused by the frequent start/stop cycles. Anyone that is is just a whiner.
I just saw an all time high of 45.1 mpg on a recent trip. Using 0w-20.The difference in efficiency from 0w-16 to 0w-20 is negligible. Driving habits are always going to have the biggest impact. Toyota’s usage for 0w-16 is fueled by fleet efficiency and CAFE standards.
careful before your car explodes and generates a black hole!I just saw an all time high of 45.1 mpg on a recent trip. Using 0w-20.![]()
