Engine air filter replacement schedule
1 reading
19K views 5 replies 6 participants last post by  vanib
I live in the snowy north with lots of salt dust in winter ..
Wondering how often you guys change the air filter ??
I'm not sure visible inspection is accurate in determining need .
Thanks
#3 ·
My 2015 Rav 4 calls for the engine air filter to be changed every 30,000 miles along with the cabin air filter. It states that both filters should be checked every 5,000 miles. My suggestion would be check them every5,000 miles and if they look dirty or getting dirty, change them when needed.
#5 ·
Depending on your road conditions, anywhere between 30,000kms to 50,000kms would be fine. Usually only need to change them every couple years. I rotate mine half way through as usually one side will pack-up with debri over the other. If you live on dirt roads and you see the filter getting dirty earlier then I would change more frequently. I checked mine on the weekend at a little over 28000kms and it still looked fine. Very little debri in the filter.
