The RAV4's sold in Canada have the windshield wiper de-icer system. What is this? I did a search, but did not find it in the search, but I'm sure it has already been addresses.
Thanks
Thanks
Mine has a seperate switch located between the heated seat buttonsJust ordered a relay for my new windshield which is equipped with wiper deicer.
On some Toyotas the rear window deicer, heater mirrors and windshield de-icer are linked and function when the rear window defrost button is pressed
In my limited 07 V6 LTD (US configuration) the rear window deicer and heated mirrors function when i press this button.
When I add the windshield deicer relay and fuse is there a way link the wiper deicer to this same switch - OR do I need to purchase a separate front window defroster switch ?
Mine has four slots - from left to rightMine has a seperate switch located between the heated seat buttons
Here is a picture of my 2008 Canadian Limited.Mine has four slots - from left to right
There does not appear to be room for an additional switch. Can you take a photo of your setup?
I can take one at lunch if you wish, but I do not have the DAC on my 07, which frees up a spot.Mine has four slots - from left to right
Downhill assist
Driver seat heating
Passenger seat heating
12v out
Not sure why that was. I was able to see the image immediately after posting, but sometimes in the past there has been a delay before the image was visible.DId not see the picture in the thread but found it in your album.
Until you mentioned it, I thought all RAVS had the seat heaters located in a single button like mine. I had a look at the 2006 electrical diagrams, and they show the L&R switches in the same housing. Since I have a 2008 and you have a 2007, I have no idea why you would have the 2 separate switches. Perhaps two separate switches appear in all RAVs that don't have the windshield de-icer.Looks like I either need to combine both seat heaters to function via a single switch (with two buttons) like yours - or run wires to the left part of the dash where I have one unused slot...
I have a 2011 with no front de-icer and I have the single combined L+R switch for the seat heaters.Until you mentioned it, I thought all RAVS had the seat heaters located in a single button like mine. I had a look at the 2006 electrical diagrams, and they show the L&R switches in the same housing. Since I have a 2008 and you have a 2007, I have no idea why you would have the 2 separate switches. Perhaps two separate switches appear in all RAVs that don't have the windshield de-icer.
Well...we are talking about tempered glass....so no risk there......I'd be reluctant to use warm liquid on a -10C -30C+ day. But I could see the use during summer
go ahead and try...let me know the results. I suspect you will be replacing the glass.Well...we are talking about tempered glass....so no risk there......
My seat heaters have both a low & high option and I want to keep it. As i see it my only option is to run a wire to the left side of the steering wheel.Not sure why that was. I was able to see the image immediately after posting, but sometimes in the past there has been a delay before the image was visible.
I don't know if the connectors on the rear of your two heater switches would be plug and play for the single heater switch. Unless you can verify that, you may wish to install the de-icer switch on the left side of the steering wheel. It's a little more work, but will cost less.
Base 2010 here and I do not have the same experience.I used factory parts, already installed wire harnesses in my 2012 base RAV4 to get my replacement windshield that came with the heating element to work. Some how the glass company ordered this, instead of the stock one(which did not come with this feature) when they replaced the broken one.
I first had the window tech plug the wiring harness of the window, into the factory plug located just below the left wiper blade.
I then ordered these parts off the net:
switch, FR wiper de icer. 84794-0R010 $49.75
RELAY. 90080-87010. $19.32
Pull out the switch panel in the rav that has the flip capped power outlet, two blanks, and the traction control. Remove the blank closest to the power outlet . Plug in deicer switch and clip into plug that is attached to the wire harness.
Open the hood and the cover of the passenger side fuse box. Insert relay into deicer location as marked on the cover. Make sure 20 amp fuse is in place.
Turn on car, turn on switch.. Feel the warmth!!!! Cost less than 100 dollars and takes 10 min or less to install.
I can hardly wait for the frost or snow in the sierras!!!
Loren
