61 - 73 of 73 Posts
If you prefer buying from Amazon then this one should work with the v14 software also
I am ordering the cable you sent link above for, from amazon.
I got the flip key from amazon and got it cut at Home Depot for free.
If I am able to program this key successfully then I would have got the whole key + cable programming for 18+ 23 = 41$. Lmao at the dealership who asked for 250$ to get me a duplicate key lol
Yes, I was able to open the door with the key, the key won’t start the car as I need to program the transponder.
I am actually trying to by pass the required key for tech stream do you have any hints on how to get a key?
Which version did you use. If you use the one I posted you just need to hit the CANCEL button and the page will disappear. Then hit connect to vehicle button and it will lock for the cable
Ps . You have to make sure you use the TS LOADER SHORTCUT button that came with version 14
I clicked on the shortcut it created on my desktop. It doesn’t seem to be pre-cracked software as I thought it to be.
I am planning to order the cable which includes they techstream key and the drivers too for windows 10.
I don’t have a windows 7 machine and this seems to take more time than I would like to spend on it, if I go with the route of ordering the cable with only win 7 drivers.
when you open techstream goto the SETUP TAB open it. Then click on VIM SELECT then make sure in the INTERFACE box it says XHOURSE-MCVI. if not open the drop down box to see if its there. if its not there then you didn't install the drivers correct
61 - 73 of 73 Posts
