321 - 340 of 1,474 Posts
Should be the same bolt pattern. Looks like they will.
Toyota RAV4 2020 2.5 VVT-i
– Generation: V (XA50) [2019 .. 2021]
– Market: USDM
– Power: 203 hp | 151.4 kW | 206 PS
– Engine: A25A-FKS, I4, Petrol
– Options: LE, XLE, XLE Premium, Adventure, Limited, TRD
– Center Bore: 60.1 mm
– Wheel Fasteners: Lug nuts
– Torque: 103 Nm
– Thread Size: M12 x 1.5
– Trim Production: [2019 .. 2020]
" title="" style="cursor: pointer;">TireRimPCD
Vehicle's recommended cold tire inflation pressure. It is measured in bars or PSI (pounds per square inch).
" data-original-title="" data-placement="bottom" title="Wheel Calculator" class="_popover" style="cursor: pointer;">
225/65R17 102H7Jx17 ET355x114.32.4
235/55R19 101V7.5Jx19 ET405x114.32.4
225/60R18 100H7Jx18 ET355x114.32.3
Looking good! This is the same tire size I've been looking at but options are slimmer. What tires did you get and I believe no rub? You figure 18x8.5 and +30 would still be safe from rub?
Thank you:). Those are the Nokian WRG4.
I have no rub issue and I think you will be safe with a +30 offset and an 18x8.5 wheel if you are using 245/55/18. The first wheels I bought were a +30 offset but they used conical nuts. When I mounted them I was only getting 6mm of thread engagement so I sent them back (that was a lot of fun...:rolleyes:) and got these which use the OEM mag style nut.
Lots of thread engagement now(y)
Oh wow! Ironically I've been running Nokian 2 and 3's and the 4 was my first choice but wasn't showing as an option online. Will have to call and ask! Thanks!
You bet!
Kal tire is who I used.
I just have to add I absolutely love them. It was like a whole new car when I got them put on. Super quiet, great traction, and they handle so nice in the rain. Haven't tried them out in snow yet but I have my Nokian R3's for that 🙂
sparco terra 17x17.5 wheels wrapped in the new Firestone Destination AT2’s 245/65/17. Spacers are up next to keep things more flush, given the +45 offset and only 7.5 width. Should I go 0.5” or 1”?
How do you like those Firestone A/T2s? I am down to them, Pirelli Scorpion All Terrain Plus and Toyo Open Country AT III for my LE Hybrid. Mine will be on factory 17x7" alloys.
Is that rig lifted?
