I purchased a new 2007 Toyota RAV4, v6, Sport. At 75K mileage, I too had to replace the water pump. Hope sometime someone determines if it should have been recalled before now.
In California it costs $400. My water pump failed at 26,000 miles. I called Toyota at 1 800 331-4331 and complained but they didn't do anything. If your water pump fails, please notify Toyota because if enough owners complain, they may issue a voluntary recall. Have you VIN handy.Just curious, what does the dealer charge to do this repair if you're paying out of pocket? And has Toyota redesigned th e pumps being used as replacements at this point?
While the water pump may be a chronic failure point in our RAVs, it is not a safety related issue so it is not subject to being recalled.I have a 2008 Rav 4 with the V6. The water pump is failing. I notice the coolant mist under the hood. We only have 24600 miles on the car. I am hoping the dealer will cover this. I scheduled an appointment on Friday morning. I see a lot of water pump problems with this car. I am curious as to why toyota has not recalled the part. Is there somewhere I can go to log the problem? Thanks
That's not right! The water pump is covered by the 5 year/60,000 mile powertrain warranty. You're still covered until November 7, 2013! BTW, I bought my Limited V6 on November 20, 2008, and I just made 27,000 miles!We have a 2008 Rav 4 V6 with 24600 miles. We bought the car on Nov 7th of 2008. When I called the dealer they told me it would be covered under the warranty. When I got to the dealer they said it was 6 weeks out of warranty. To make a long story short, i convinced the dealer to fix the friggin part.
Do you have reason to believe that RAV4 water pumps fail at a higher than average rate?About the RAV4 V6 water pump problem, it would be appropriate for Toyota to do what Honda has done, in relation to another situation.
Yeah, on one level that V6 pump reliability problem is logical since the years showing the most problems likely have more miles on them. If I recall correctly Toyota's later model year pump has a different part number. On this forum I'd asked if later years actually have a revised/different pump and if so, is it actually different from the old one - no answers so far. Tried searching on the Toyota site re parts - only info is a dealer locater. :wallWhile researching Ravs on Consumer Report's site the ratings showed problems with engine cooling on 2006, 2007, & 2008. Ravs from 2009 through 2012 didn't show problems with engine cooling in the ratings.
Let's hope that your replacement pump lasts as long as you have the vehicle! What do you think is in the pink coolant which could be causing a problem with the pump? Based upon your experience with your 2010 V6 it appears that Toyota may not have solved the pump problem which has been prominent with earlier V6s.2,600 miles since WP replacement, so far so good. I'm skeptical it will last 100,000+ miles but sincerely hoped it would proves me wrong . . .
I don't think that pink life-time coolant is contributing to the longevity of the water pump. Changing the coolant every 60,000 miles or 3 years couldn't hurts?:shrug:
